[phpBB Debug] PHP Warning: in file /includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Warning: in file /includes/bbcode.php on line 112: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Warning: in file /includes/functions.php on line 4594: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3765)
[phpBB Debug] PHP Warning: in file /includes/functions.php on line 4596: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3765)
[phpBB Debug] PHP Warning: in file /includes/functions.php on line 4597: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3765)
[phpBB Debug] PHP Warning: in file /includes/functions.php on line 4598: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3765)
Club Renault Sverige Forum • Visa tråd - Renault Clio 16v MK1 - The Underdog
Club Renault Sverige www.clubrenaultsverige.com
Författare Meddelande
<  Mitt Renaultprojekt / Renovering  ~  Renault Clio 16v MK1 - The Underdog
InläggPostat: lör 14 mar 2015, 23:28
Inlägg: 25Ort: KungsbackaBlev medlem: mån 31 mar 2014, 11:47
_________________
I'd rather loose by a mile because i built my own car, than win by an inch because someone else built it for me. Your car is YOUR story, so don't let someone else write the book.
//Linus Olausson
Offline Profil
InläggPostat: sön 15 mar 2015, 00:03
AnvändarvisningsbildForumpolisInlägg: 8465Ort: TimmernabbenBlev medlem: sön 12 jan 2003, 20:40
Det brukar vara så, jag har en hel del dyra motordelar kvar, bara koppling/svänghjul är över 1000£ :(
_________________
Offline Profil
InläggPostat: tis 17 mar 2015, 20:34
AnvändarvisningsbildForumpolisInlägg: 4268Ort: StockholmBlev medlem: lör 21 dec 2002, 23:20
Ballt projekt!
Trimma är skoj... men dyrt 8)
_________________
Offline Profil
InläggPostat: tor 19 mar 2015, 10:33
_________________
//Linus Olausson
Offline Profil
InläggPostat: ons 05 aug 2015, 12:14
Här har de varit riktigt dött de senaste, ber om ursäkt för detta. Nu har jag iaf kommit lite på vägen, igår flyttade jag tillbaka motorn till mitt garage, och fick tummen ur röven och momentdra alla bultar i botten på motorn.
Tyvärr så glömde jag tråget samt oljepumpen se de blir till att skruva dem idag.
Dra lite moment va de ja!
När jag insåg att arp inte va torx så blev de, wooooow kommer vi aldrig hitta i rätt storlek, 30min senare va vi tillbaka i garaget och skruvade ihop skiten, tacka gudarna för swedol!
_________________
//Linus Olausson
Offline Profil
InläggPostat: ons 05 aug 2015, 12:45
Då har du gjort mer än mig, iaf på bilen :)
_________________
Offline Profil
InläggPostat: mån 01 feb 2016, 00:05
Då va de dags för en långsam uppdatering igen!
Men idag har jag varit och fixat till en ny kolv med hjälp av en kompis!
Såhär såg de ut innan, den till vänster har fått sig en kyss av en ventil och den till höger är orginalkolv
Här har vi den där rackarns stora materialborttagaren ^^
Här har vi börjat met att svarva ned en liten bit på ytterkanten, här kan man oxå se att de som gjort de kolven som vi har som "mall" har gjort ett rätt dåligt jobb, man kan se samt känna de olika skären... på den som vi tillverkat nu kan man bara se dem inte känna dem!
Här kör vi första urtaget!
Här har vi första och andra urtagen
Fyra urtag klara!
Och här har vi när allt är finito! :D
Kan ju säga att detta blev sanslöst mycket bättre än den äldre kolven! Nu ska jag bara gå över och fixa alla grader.
Jag viktade även kolvarna mot varandra och det diffade inte ens en 100del på dem. Vilket jag anser som ett jävligt lyckat jobb!
_________________
//Linus Olausson
Offline Profil
InläggPostat: ons 03 feb 2016, 21:51
Såja då har vi slängt i den nya kolven :D
_________________
//Linus Olausson
Offline Profil
InläggPostat: fre 04 mar 2016, 08:31
Inlägg: 5Ort: BoråsBlev medlem: fre 04 mar 2016, 08:18
Jag undrar om du har några fälgar liggandes, tex 16v original turbine fälgar, till min Clio Williams?
/Ronald
_________________
Ronald Motten
Offline Profil
InläggPostat: sön 12 mar 2017, 04:21
Här har de stått väldigt still, men nu efter garagebyte och massa annat som kommit ivägen så har de börjat få fart igen! Även med lite mer saker!
Nya garaget, samt ni kan även se att jag skaffat ett svart skal, som antingen ska leka donator eller leka ersättare, det är inte riktigt bestämt ännu.
Har tagit ur förarstolen då ramen va skev, har skaffat två nya framstolar men skall byta tyget mellan dem båda.
Athena MLS-Packning för toppen
Var en sväng till gamla garaget, hittade en låsring till en kolvbult... lagom kul att behöver riva ner hela bottendelen igen för att kolla så man inte missat någon.
På med sumpen igen
Toppen ditlagd
Mätning av nedtryck på alla ventiler (den slår inte i något i alla fall)
Ny rem, spännare, löphjul, vattenpump samt på med den den skumma givaren för att tända med haltech'et
_________________
//Linus Olausson
Offline Profil
InläggPostat: sön 12 mar 2017, 13:47
AnvändarvisningsbildInlägg: 2897Ort: UppsalaBlev medlem: mån 24 jul 2006, 17:54
Härligt!
_________________
Albert Sjöberg - Uppsala
Nu: Zoe R240 Intens -16, Twizy -13, Grand Scenic 1.6dci S&S -12, Mégane II RS -08, R20TS R1272 -79, R16TL R1156 -77, R16 R1150 -67
Offline Profil WWW
InläggPostat: fre 27 apr 2018, 19:37
Nu tror ni säkert att jag har legat på latsidan... och det är helt korrekt det har jag verkligen, det har varit väldans sporadiska besök i garaget det senaste året. Men nu har det börjat ta lite fart igen. Här kommer tre sektioner med saker som jag har gjort det senaste halvåret i alla fall enjoy!
Styrsystem
Jag valde bort mitt uråldriga Haltechstyrsystem mot att köra på Speeduino, ett opensourcebaserat styrsystem som har en arduino mega i grun och botten, jäkligt kompetent stysystem för iprincip inga pengar alls. En fantastisk community bakom och fruktansvärt mycket kompetent folk!
Här kan ni läsa lite om det, om det skulle vara mer intressant!
Här kör jag speedyn med en simulator, detta för att se så den faktiskt gör det den skall (Ardustim), dem tre vridpotentiometrarna är för varvtal, insugsluftstemperatur samt vattentemp.
Jag har planerat att konvertera motorn från rotor och fördelare till att dels köra coil on plug, och även i framtiden full sekventiell tändning samt sprut, men efter många timmar utav att inte få gnista på styret så visade det sig att det var fel motstånd på tändsignal ut från ECU'n så dem fick bytas.
I samma veva som jag köpte styrsystemet från koop här på forumet så köpte jag även en bredbandslambda från honom som passar för att köra autotuning på speedyn, vilket är jäkligt smutt om jag får säga det själv!
Nya prober skaffades till mitt oscilloskop för att kunna felsöka sagda fel ovan!
Här mäter jag för att kolla så faktiskt speedyn ger ifrån sig rätt signal till spolarna.
Styrsystemet skall senare monteras in i denna box, vilket är orginalboxen till motorn, så man kan köra med orginalhärvan!
Lyckades även hitta rätt på spolar som passar rätt i från en Honda K20 motor! Jäkla behändigt, samt bara tre tåtar. 12v, jord samt signal.
Transmission
För att vara kompatibelt med speeduinon så måste jag ha ett svänghjul som man kan köra den på, här ser ni ett lättviktssvänghjul från 5kg ner till 2,9kg, med 60-2 trigger passar PERFEKT med speedyn samt kopplingen som jag har.
Koppling då, som ni kan se så är den jäkla ledsen, så det blir till att köpa 8st ny puckar och sula på den rackaren innan de monteras
Motorstuff
Sedan va det dags att hysta på ITB'erna igen och om jag får säga det själv så är den förjäkla sexig med dem på!
Spridarna visade sig att vara 940 Turbo spridare, ingen aning om det är bra eller dåligt, med det funkade innan så då funkar det säkerligen nu!
Då en annan renault i kompisgänget hade problem med sitt oljetråg så fick jag offra mitt, samt laga upp detta! Sprucket i botten samt oljepluggen helt åt helsicke! Men nu är det helt.
För att jag skulle få plats med ITBerna så va jag tvungen att kapa lite på topplockspackningen som stack utanför block/topp, kan helt klart säga att dem där jäkla packningarna är HÅRDA!
Här ser ni även det magnifika hemmabygget till fuelrail som förra ägaren har lött ihop, hoppas de håller tätt!
Rostlagning
Nu till det absolut tråkigaste med hela bilen... ROST jäkla bilcancer, jag har fruktat att ta tag i detta sedan jag skaffade bilen. Notera detta är första gången som jag någonsin svetsat samt gjort något liknande, så om mina svetsfogar (punktar) ser konstiga ut så är det därför. Har ni några tips och trix så tas det gärna emot!
Upp med bilen på pallbockar så man kommer åt!
Kapa bort yttertröskel
Slipa bort så mycket som det bara går...
Svetsa dit ny plåt
Bygg lite nytt golv
Bocka ny plåt och svetsa (den plåten tog mig över en timma att få rätt profil på, är ändå relativt nöjd.
Nu behövs en del bodyfiller, primer, lack och ett jäkla massa slipande!
_________________
//Linus Olausson
Offline Profil
InläggPostat: ons 16 maj 2018, 11:05
Har blivit lite mer gjort,
Slipat och grundat innanför yttre sidoblaken
Sedan va de dags att bocka till en ny yttre balk, samt svetsa på den rackaren!
och sedan slipa bort alla stackars loppor
_________________
//Linus Olausson
Offline Profil
InläggPostat: sön 11 nov 2018, 15:00
Det tar lång tid mellan mina uppdateringar jag vet men här kommer lite till! :D
Det är alltid mer rost änn vad som visar sig på utsidan, så fick kapa en del på bakskärmen tyvärr.
Sist på med lite rostskyddsprimer!
Fick även tag på ett par tvärgulliga 4-kolvs wilwood ok! Skall köpa en ny kolv och packningskit till dem så borde man kunna köra med lite mindre fälgar änn om jag hade kört med 4-kolvs brembona som jag också har liggandess.
Har även måttat upp lite kamaxlar som va status okänd på!
1-2: Org clio 1,8 16v 3-4: Kentcams eftermarknads 5-6: Clio Williams
Sedan har jag även börjar finurla lite och bygga med min 3D-skrivare, här är clips för att hålla fast dörrlisterna, dem är helt omöjliga att få tag på nya eller typ hela över lag, så håller på att testa mig fram lite!
Sedan va de dags för lite mer rostlagning av hjulhuset bak.
Samt spackla slipa samt på med lite färg på tröskeln.
Ville även få till sekvensiell tändning samt soppa på styrsystemet, så designade en hållare för att få cam-position! Nu sulade jag bara dit en ABS-givare för att se så det funkar, skall dit en riktig honeywellsensor (Hall) i ett senare skede.
_________________
//Linus Olausson
Offline Profil
Visa inlägg nyare än:  Sortera efter:
Alla tidsangivelser är UTC + 1 timme [ Sommartid ]
Sida 2 av 2
29 inlägg
Gå till sida Föregående  1, 2
Användare som besöker denna kategori: Inga registrerade användare och 2 gäster
Sök efter:
Ny tråd  Svara på tråd
Hoppa till:
Du kan inte skapa nya trådar i denna kategori
Du kan inte svara på trådar i denna kategori
Du kan inte redigera dina inlägg i denna kategori
Du kan inte ta bort dina inlägg i denna kategori
cron
